Hi i'm SeonHo
i created thing using MQTT extensions
it was good working
when i pub, thingworx get sub
but i In spite of checked persistent
after click Save, property value go disappear
why? any suggestion for me?
thanks
It's like what in the errors: Not authorized for PropertyRead on temp in TestMqttThingLocalhost
You may need to give Run time permission for Property Read for the login user of Thing TestMqttThingLocalhost.
Br,
Anna
Actually, I solved it. just now
i don't know how i solved this
guess it is after click cancle edit.
thanks
Glad to hear that.
Please let us know if it happens again.
There is an known similar issue for Kepware connection to ThingWorx; it's probably fixed in ThingWorx 8.1.0.
Anna
Ha...
another issue came to me
i was login as admin
i created a subscript of datachange which parseFloat
because mqtt data fomat is string
but error when datachange
Execution error in service script [TestMqttThingLocalhost temp.DataChange] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Not authorized for PropertyRead on temp in TestMqttThingLocalhost Cause: Not authorized for PropertyRead on temp in TestMqttThingLocalhost
it was still error after permission runtime, designtime
thanks
Br,
Anna
