Hi, why i don't have the import and export button?
slua
Hi, i cant seems to find my Import & Export button, is it due to i dont have the rights? button.png
8 REPLIES 8
adrianpet
(To:slua)
     You need Administrator rights in order to use the import/export feature in Thingworx.
Best regards,
Adrian
slua
(To:adrianpet)
thanks !
slua
(To:adrianpet)
Adrian, can i ask you one more question? my VM simulator can work but now they it shows cant connect to my to my end point, what is the problems?
Aanjan
(To:slua)
Can you post the entire log? Also, what are your current configurations set in in the TrainingConfig file?
slua
(To:Aanjan)
thanks
Aanjan
(To:slua)
Can you try using localhost or your actual IP instead of 127.0.0.1 in the TrainingConfig.json? Also, just to make sure, the Platform is available at port 80, correct?
slua
(To:Aanjan)
I tried to use my own IP and its connected but then the handshake part keep timeout. As for the port 80 its available and i am using it,
slua
(To:Aanjan)
here the picture of the simulator
