Hive Connection from Thingworx using JDBC Driver
pharlapur
Hi All,
We are facing issue while connection to Hive Table in one of the Hadoop instance.
Details of the Hadoop instance
Version : Hadoop 2.6
Access : Hive tables
Driver plugin used for Hive "hive-jdbc-0.14.0.jar"
Error
Confguration on the JDBC Database :
Please let us know what can be the solution for this.
Prabhas
3 REPLIES 3
paic
(To:pharlapur)
You don't seem to have a validation string entered in, that is something that is needed.
A validation string is basically a statement that will execute on the database.
pharlapur
(To:paic)
Hi Pai,
Thanks for the reply.
I have used SELECT NOW() in validation string , but still it seems to be giving same error.
Prabhas
Hi Prabhas,
could you solve your issue?
I am facing the same error message at the moment.
Arian
