Hive Connection from Thingworx using JDBC Driver
pharlapur
1-Newbie
Hi All,
We are facing issue while connection to Hive Table in one of the Hadoop instance.
Details of the Hadoop instance
Version : Hadoop 2.6
Access : Hive tables
Driver plugin used for Hive "hive-jdbc-0.14.0.jar"
Error
Confguration on the JDBC Database :
Please let us know what can be the solution for this.
Prabhas
3 REPLIES 3
paic
1-Newbie
(To:pharlapur)
You don't seem to have a validation string entered in, that is something that is needed.
A validation string is basically a statement that will execute on the database.
pharlapur
1-Newbie
(To:paic)
Hi Pai,
Thanks for the reply.
I have used SELECT NOW() in validation string , but still it seems to be giving same error.
Prabhas
avanhuelsen
6-Contributor
(To:pharlapur)
Hi Prabhas,
could you solve your issue?
I am facing the same error message at the moment.
Arian
