How can i color a shape using 3 variables containg RGV values each from [0,255] ?
LaurentGermain
6-Contributor
I would like to color a shape based on 3 variables containing  RGB integer values.
ie
R=255
G=0
B=0
Should lead to a shape colored in Red
3 REPLIES 3
I would suggest you look into custom extensions, and by adding a graphic library to your extension you could write a service to do so (for example, opengl).
rnayak-2
(To:LaurentGermain)
You can use style definition to define this for existing widgets. Define new style definition and then assign different RGB values while picking the color. I hope that helps!
Your answer would work if i had only a few values, but It is clearly not realistic to create 256*256*256 Styles  definitions ;-)
