11-Garnet
September 11, 2024
How can i customize thingworx mashup url?
  • September 11, 2024
  • 4 replies
  • 1177 views
I have an application starting mashup named org.proj.entity.name.type
I would like to customize this starting page url or redirecting from customized as mentioned below
https://<host>/Thingworx/Runtime/index.html?mashup=org.proj.entity.name.type
How to customize this to https://<host>/projectHome
thanks,
janakiraman P
Rocko
In ThingWorx I don't think this is possible. You would have to configure Tomcat to rewrite the URL, maybe this helps:
https://tomcat.apache.org/tomcat-9.0-doc/rewrite.html
What you can do in ThingWorx OOTB, it's to point <yourURL>/Thingworx/Home to a mashup which is defined on the User properties called "Home Mashup"
Guillaume
Not sure about your ask, however if you want a consistent URL you may go with Contained Mashup, internally mashup will be changing, but URL will be consistent.
18-Opal
March 20, 2025
There is an article that helps you redirect to another URL or the format; the configuration changes need to be done on the Tomcat Side.
Below is a similar article that will help you find a solution.
Article - CS353656 - How to configure Thingworx Navigate to access LandingPageAccessAppMashup with a short URL?
