I am just a beginner of the ThingWorx platform. Does thingworx provide any facility to send alert messages via SMS or email? If yes then how?
Hi Stuti,
You can use the Mail Extension available in the Thingworx Marketplace to send emails and email to SMS addresses, over SMTP. If you want to send native SMS you would need to use an service like Twilio which also has an extension available in the Marketplace. These are free downloads.
Link to Marketplace... http://marketplace.thingworx.com/
Adam
Thanks Adam. I'll try that out. :-)
Hi Adam,
Is there any option other than 3rd party subscription like Twilio? Some customization is possible in TWX to send SMS?
Java (which is what extensions are written with) does not have any native libraries for sending SMS messages. There are some third party libraries out there that could be used to build an extension. I do not have any knowledge or experience with these so I would not suggest any specific one. From the Thingworx side we have always recommended using the mail extension to send messages, though this is limited to only send and the SMS must have a valid email address.
Hi Adam,
Twilio extension seems to be no more available on the market place. Can you please check.
Regards
Swaraj
when I download and try to import on my composer then am getting this error.
Hi Mahaboob Basha,
Restart your ThingWorx and try to import extension again. If the issue persists; I would suggest you to open a Technical support case with PTC.
Ankit Gupta
Hi Adam, I tried to use Mail Extension. I set up the configuration and send an email over SMTP. It works but when I tried to send SMS, I can't is there any configuration that I should change? Any specific format for the SMS address? Looking forward to your response.
Evan
