How custom event trigger any service?
bgupta-2
9-Granite
Dear Team,
6 REPLIES 6
You just need to subscribe to the corresponding event, and on the subscription code you can call any service.
hi
i have the same problem, and the problem is with subscription code.
I am new to TWorx and still trying to find my way in it.
I have a timer which i created a subscription to it from my thing, my thing has a service which i want it to run when ever the timer fires, but still i can't figure out what code i have to add in my subscription to execute the service.
can you help please
If you have a service implemented on the Thing, you just need to call it from the subscription:
me.myServiceName();
That's all.
thank you for your reply.. and I tried it but the property value did not get updated ...
I am not trying to give any one a hart attack.. but i attached a screen shot I hope it can give you a clue..
the services I am trying to run , call some property values from a remote server..
when I use the test button on the service page it's run perfectly and the property values change.. but with the timer thing, nothing get updated...
i tried :
me.myServiceName(test3);
me.test3();
me.test3(test3);
but nothing change ...
sorry again... and thank you for your help...
by the way.. the output of test3 is an XML file with some property value.
I added anther service the give a random number and it worked fine ...
but still the first service "test3" do not get executed .. and property value do not change ....
thank .. it worked , i just restarted my PC and start from scratch ...
