Hi @Huaxu,
There is no ThingWorx OOTB API that allows creating a Mashup through code.
The Mashup is an entity type that is supposed to be edited and created through Composer only.
Can you please share more details of your use-case so we may suggest an alternative path?
Hi @Huaxu,
I wanted to be able to generate mashups directly from the template from code, which would greatly improve my development efficiency
As Vladimir says, there doesn't seem to be any way of creating mashups through a service.
But there is an entity type called "Dashboard" which could perhaps be used in your use case:
Find more information here.
Jens
