I am trying to create a button in a mashup that will change the value of a property of a Thing to 1 when pressed and 0 when not pressed.
Any help would be appreciated. I'm new to ThingWorx and this is probably a simple thing to do.
Hi @acurtin.
Have you tried using the Button widget?
Since you're new to ThingWorx, I would recommend checking out these training guides available on our Developer's Portal:
Getting started with ThingWorx for IoT
You will need to create an account to access them.
There are many other training guides available there so feel free to check them out.
--Sharon
@acurtin I just wanted to follow up with you to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question. If you are still experiencing issues, please do let us know your questions or concerns.
Vibhuti
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
