How do I enable services for user/group?
pbaierl
I have created a mashup that has a grid to show my available unit serial numbers and their status.  I also have a good map widget to show the unit location.
I use the GetTableEntries Service to load the grid and populate the unit locations on the map.  I created a group and added a member to that group.  The new user has full permission to read/write properties, execute services, subscribe to events, and execute events.  When I view the mashup as the user I see an error that the GetTableEntires service does not have permission to run.
Any help with what I am missing would be greatly appreciated.
Thanks!
nkhose
(To:pbaierl)
Hi ,
One thing is doable in this case , log-in as Administrator open the Datatable "VehicleDataTable"  then in left navigation you can see Permission section
add the User to the Runtime & Design -Time giving proper CRUD operations .
Hope this helps to move forward on this for you !
8 REPLIES 8
Are there any other errors reported in the Application Log when you try to access this service?
Meghan
Here is the only issue I saw in the log.  If I log in as an administrator I can see the mashup working fine.
That's the Mashup log, if you actually go to Composer->Monitoring->ApplicationLog I'm hoping there are more errors in there that would identify exactly what services on what entities you need to grant permissions to.
I do not see any errors in the log.
Aanjan
(To:pbaierl)
Paul, can you try logging in as that User, access that specific Thing, navigate to the Services section and run the same GetDataTableEntries ?
pbaierl
(To:Aanjan)
No, the user I created cannot view the data table that contains the GetDataTableEntries.
You do not have permission to view "VehicleDataTable"
nkhose
(To:pbaierl)
Hi ,
pbaierl
(To:nkhose)
Thanks this solved my problem.  Appreciate the help!
