How do I read XML tag value when it contains namespace like ns0:
Newbie
I have a soap response from a PostXML call.
Need help in reading the value of a tag: Ticket_number
I am not able to read the value TKT0001, more so because of the namespace
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <soapenv:Body>
  <ns0:Test_soap_service xmlns:ns0="urn:Create_Ticket" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <ns0:Ticket_Number>TKT0001</ns0:Ticket_Number>
  </ns0:Test_soap_service>
  </soapenv:Body>
  </soapenv:Envelope>
Tags (1)
Re: How do I read XML tag value when it contains namespace like ns0:
Hello, Ranjan.
Are you getting an error thrown when you try to read TKT0001, or getting an empty value? If there is an error, what is that?
-- Craig A.
try the below ! where 'response' is the soap response you got from the web service
var result= response.*::Body.*::Test_soap_service.*::Ticket_Number
Thanks Raghu
It worked..
