How do I reference the mail server in order to send out alerts
tcain
I have gotten the mail server to send out a test email successfully. Now I need to build some logic that will  send out an email alert if an input goes over a certain value. I am just not sure how to reference the Mail Server.
Toby
5 REPLIES 5
ds-21
7-Bedrock
(To:tcain)
Hi Tobias,
              In mailServer template has sendMessage service. you can use that service in your Thing or template (i.e sampleMailThing).
if(me.temp>40)
var params = {
  cc: undefined /* STRING */,
  bcc: undefined /* STRING */,
  subject: undefined /* STRING */,
  to: undefined /* STRING */,
  body: undefined /* HTML */
me.SendMessage(params);
or
You use subscription to achieve this
1) create new subscription
2) choose event as data chage.
3) choose the desired property.
4) check the Enable check box
tcain
(To:ds-21)
Thank you for the help! I got that to work creating a property in the MailService it self, but I was hoping to pull a property that I am reading from API to compare to. Should I re-read the API in order to get that property or is there a way to pull those values in from a different Thing.
Thank you,
Toby
ds-21
7-Bedrock
(To:tcain)
Hi Tobias,
    if your API values are stored in Property. you should do one thing, instead of me.temp(in above solution).use var value = Things["ThingName"].PropertyName .This will get the value of the another thing property value.
​I hope this help helpful.
Dinesh
ttielebein
(To:tcain)
Hey, you may want to consider marking one of these answers as correct if it helped you so that others can find the solution as well
ankigupta
(To:tcain)
Hi Tobias Cain​,
You can use subscription for that. To reference the mail server; go to entities tab in your subscription and select the mail entity and then the service. You can insert the corresponding javascript code by using the arrow key.
I hope it helps.
Ankit Gupta
