I created a thing using CreateOrUpdateThingTemplateForModel service of TW.AnalysisServices.ModelManagementServicesAPI resource. After mapping properties in thingworx analytics manager I see few properties like goalName,causalTechnique,data,dataCollection,importantFieldCount,key . Now I am able to test the prediction scoring feature by setting values in "data" property manually. These values are being sent to thingworx analytics manager and I see the predicted values in dataCollection property.
My question is how do I set the values in data property so that these values are sent to thingworx analytics manager. Is there any service to do so?
I manually created a service as below but no luck as these values were not sent to thingworx analytics manager. Please help me to understand this. Appreciate your help.
var params = {
infoTableName : "InfoTable",
dataShapeName : "ThingPredictor.bearing_data_Condition_417.InputParamsdataDataShape"
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var newEntry = new Object();
newEntry._B1 = 131.73;
newEntry._B2 = 167.94;
newEntry._B3 = 350.01;
newEntry._B4 = 561.75;
newEntry._B5 = 267.51;
newEntry._B6 = 349.78;
newEntry._B7 = 130.8;
newEntry._B8 = 29.01;
newEntry._condition = 0;
newEntry.key = 0;
logger.warn("Created info table");
result.AddRow(newEntry);
// setting the property data
me.data = result;
Hello Azim,
Please refer the below link and suggest if it solves your issue:
Prakhar Shubham
Hello Prakhar Shubham,
This video shows setting values for property "data" manually. I have to do it through service so that this service I can use on mashup. Any suggestions?
Azim
