The Thingworx platform I deployed doesn't work today.
The version I installed is Thingworx 7.3 . And Used the postgresql 9.4 as database.
When I used the url "localhost/Thingworx" to visit the platform, it displays like the picture below.
And this is log file in Tomcat
2017-09-26 14:40:46 Commons Daemon procrun stdout initialized
Attempting to load ESAPI.properties via file I/O.
Attempting to load ESAPI.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\ESAPI.properties
Loaded 'ESAPI.properties' properties file
Attempting to load validation.properties via file I/O.
Attempting to load validation.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\validation.properties
Loaded 'validation.properties' properties file
*** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connections could not be acquired from the underlying database!
*** Web Application STATE is being set to ERROR! ***
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called
2017-09-26 15:00:30 Commons Daemon procrun stdout initialized
2017-09-26 15:07:51 Commons Daemon procrun stdout initialized
wish your help!
Thanks Janet Joseph Antony Dass
I followed the article. When I checked the PostgreSQL logs, there was an error about pg_hda.conf.
The platform works again.
Hi yz ding,
Please try the resolutions given in this Article. And let us know if you still face any issues.
Ensure your postgresql db is running (in pg admin III, you may right click on the database to establish connection as an option from the selection).
