How i can set properties in GetImplementingThingsWithData
PTCuserFrom
2-Guest
I have Tractor things (Tractor_General_Template => Wheat_Tractor_template or Rice_tractor_template).
I have Mashup with GetImplementingThingsWithData from Tractor_General_Template.
I have question : How i can set fuel properties for selection tractor?
mashupmashup
posipova
20-Turquoise
(To:PTCuserFrom)
You'll have to use another service to set the properties (either use one of the existing services or write your own using the snippets). You'll then bind/feed the data to the service and execute it to update the properties.
posipova
20-Turquoise
(To:PTCuserFrom)
Thank you! I created new thing for scripts "ScriptThing" and execute service from his. Its ok?
posipova
20-Turquoise
(To:PTCuserFrom)
Just following up to see if the issue has been resolved.
posipova
20-Turquoise
(To:PTCuserFrom)
