How long of properties name of thing?
Hi @ssriuaipornchai.
Here is a link to a page in the ThingWorx Help Center with the requirements around property names. However, it does not indicate a maximum length.
Are you running into an issue?
--Sharon
--Sharon
Ok thank you
I just need to know.
I test with 2000 character, It pass and can create
If you are satisfied with the previous response, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
