How to Access Pdf File from my ThingWorx System Repository
Abhishek_Tirkey
11-Garnet
I have a pdf file in my system repository. How can I access that pdf kept in System Repository?
Abhishek Tirkey
Hi @Abhishek_Tirkey, If you want to show a PDF file from the repository to runtime or something else, look at the article below. If you're going to display your file in a mashup, then use a web frame widget.
https://www.ptc.com/en/support/article/CS346276
2 REPLIES 2
Thank you @Surya_Tiwari , that worked for me.
File Location - System Repository
File Name - file.pdf
So the URL to access the pdf will be (Change host and port [localhost:8080] according to your device) -
http://localhost:8080//Thingworx/FileRepositoryDownloader?download-repository=SystemRepository&directRender=true&download-path=file.pdf
Abhishek Tirkey
