How to Access Pdf File from my ThingWorx System Repository
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I have a pdf file in my system repository. How can I access that pdf kept in System Repository?
- Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Abhishek_Tirkey, If you want to show a PDF file from the repository to runtime or something else, look at the article below. If you're going to display your file in a mashup, then use a web frame widget.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thank you @Surya_Tiwari , that worked for me.
File Location - System Repository
File Name - file.pdf
So the URL to access the pdf will be (Change host and port [localhost:8080] according to your device) -
