Hi Everyone,
I like to Create Datashape through TWX service with multiple number of Fields.
I found the Snippet in Thingworx its like.
var params = {
name: undefined /* STRING */,
description: undefined /* STRING */,
fields: undefined /* INFOTABLE */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateDataShape(params);
but i don't know How to give fields in the above snippet.
if anybody Know any solution regarding this,Kindly share it ASAP.
Thanks & Regards
Sugumar R
You should pass an Infotable with the desired fields formats, or a JSON Infotable, here an example of the second opcion:
var fields = { dataShape: {"fieldDefinitions": {"fieldName1": {"name":"fieldName1", "aspects":{}, "description":"", "baseType":"NUMBER", "ordinal":1}, "fieldName2": {"name":"fieldName2", "aspects":{}, "description":"", "baseType":"INTEGER", "ordinal":2} } }, rows: [] }; Resources["EntityServices"].CreateDataShape( { name: "newDataShapeName", description: undefined , fields: fields, tags: undefined });
Hello @Sugumar_5656
PFB snippet to add Field Definition to Datashape
var params = { name: FIELDNAME /* STRING */, description: undefined /* STRING */, type: 'NUMBER' /* BASETYPENAME */, ordinal: undefined /* INTEGER */, primaryKey: undefined /* BOOLEAN */, dataShape: undefined /* DATASHAPENAME */ }; // no return DataShapes[DatashapeName].AddFieldDefinition(params);
VR
Hai Velkumar,
Thank You for your reply.
I already used the snippet what you shared. It is actually used to add fields one by one to the already created Datashape.
But i required to create multiple number of fields when i am creating the data shape itself.
Thanks & Regards
Sugumar R
