How to Create Data shape Through Service in Thingworx
Sugumar_5656
Hi Everyone,
I like to Create Datashape through TWX service with multiple number of Fields.
I found the Snippet in Thingworx its like.
var params = {
name: undefined /* STRING */,
description: undefined /* STRING */,
fields: undefined /* INFOTABLE */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateDataShape(params);
but i don't know How to give fields in the above snippet.
if anybody Know any solution  regarding this,Kindly share it  ASAP.
Thanks & Regards
Sugumar R
You should pass an Infotable with the desired fields formats, or a JSON Infotable, here an example of the second opcion:
var fields = { dataShape: {"fieldDefinitions":
                              {"fieldName1":
                                   {"name":"fieldName1",
                                     "aspects":{},
                                     "description":"",
                                     "baseType":"NUMBER",
                                     "ordinal":1},
                               "fieldName2":
                                   {"name":"fieldName2",
                                    "aspects":{},
                                    "description":"",
                                    "baseType":"INTEGER",
                                    "ordinal":2}
               rows: []
Resources["EntityServices"].CreateDataShape( {
	description: undefined ,
	fields: fields,
	tags: undefined
Hello @Sugumar_5656
PFB snippet to add Field Definition to Datashape
var params = {
 name: FIELDNAME /* STRING */,
 type: 'NUMBER' /* BASETYPENAME */,
 ordinal: undefined /* INTEGER */,
 primaryKey: undefined /* BOOLEAN */,
 dataShape: undefined /* DATASHAPENAME */
 // no return
 DataShapes[DatashapeName].AddFieldDefinition(params);
VR
Sugumar_5656
(To:Velkumar)
Hai Velkumar,
Thank You for your reply.
I already used the snippet what you  shared. It is actually used to add fields one by one to the already created Datashape.
But i required to create multiple number of fields when i am creating the data shape itself.
Thanks & Regards
Sugumar R
                              {"fieldName1":
                                     "aspects":{},
                                     "description":"",
                                     "ordinal":1},
                               "fieldName2":
                                    "aspects":{},
                                    "description":"",
                                    "ordinal":2}
               rows: []
	fields: fields,
	tags: undefined
Sugumar_5656
(To:CarlesColl)
Thank you so much CarlesColl ...
Its Working Perfectly CarlesColl .
Thanks& Regards
Sugumar R
