How to Create Notification Feed in Thingworx
VS_9760165
Hi ,
I am looking to create Notification Feed in Thingworx. when i click on button ,Popup will be open. but below are my questions..
1.How to add dynamic row feed into popup?
2.how to show unread notifications in Number ? below screenshot you can refer to get my requirement.
PaiChung
22-Sapphire I
(To:VS_9760165)
Aside from a custom widget, probably a pop-up mashup
you can use the GetProperties - Push updates ability to make that mashup pop-up
then run services to retrieve the information needed to be displayed.
Also that same GetProperties - Push can set the number in your top bar.
PaiChung
22-Sapphire I
(To:VS_9760165)
tdixit
(To:PaiChung)
Hi @VS_9760165
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thanks & Regards,
Toolika Dixit
