How to Navigate ASP.NET webpages to Thingworx dashboards. Is it possible?
sdaram-2
2-Explorer
I have web application which developed by using ASP.NET . I want to navigate from .NET web pages to Thingworx dashboard. is there any possibility to do that.
3 REPLIES 3
supandey
(To:sdaram-2)
Hi Spandhana, if the question is just about navigating you could use the URL to the Mashup that contains the dashboard for navigating. Something like this http://<serverName>:8080/Thingworx/Runtime/index.html#mashup=DefaultMashupToEditGadget
Have you already tried that?
jgorsline
(To:sdaram-2)
Spandhana,
Any update on this? Was Sushant Pandey's post helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
My Issue Got Resolved. I am able to Display Thingworx Mashup in Iframe Control of my Webpage.
Steps I have done
1) I have followed below step mentioned in Release notes.
Description
Required Steps
Remove all clickjacking protection
  1. a. Locate the following section of code in the web.xml and comment it out:
  2. b. <!-- use the SameOrigin version to allow your
  3. c. application to frame, but nobody else -->
  4. d. <filter-mapping>
  5. e.        <filter-name>ClickjackFilterSameOrigin</filter-name>
  6. f.        <url-pattern>/*</url-pattern>
                 </filter-mapping>
Currently i am using Thingworx 7.3
2)
<iframe id="if1" width="500" height="390" style="visibility:visible" src="http://localhost:8080/Thingworx/Mashups/PGCGraph? appKey=0f4b4662-7d09-46c3-a766-bbbcfa73ad99&x-thingworx-session=true"></iframe>
Mashup URL I am giving like this
here PGCGraph is Mashup Name.
I have Created User (Example:User123) and I Have created Appkey( 0f4b4662-7d09-46c3-a766-bbbcfa73ad99) and assigned created user (User123 to appkey.)
3)For Mashup i have assigned user in Design Time and Run time Permission.
With above steps i am able to get my mashup in iframe.
Spandhana Daram
