How to Navigate form google widget to multiple mashups base on double click on the respective location
akesana
We have 5 locations on google map widget on double click of any of the location we are able to navigate single mashup.
But we have 5 mashups for 5 locations we want to navigate to respective mashup on double click of that location.
Could anyone help us to achieve this thanks in advance.
Anil Kesana
posipova
20-Turquoise
(To:akesana)
You  may look into using Tooltip mashup, upon binding locations to correspondant tooltip locations:
akesana
(To:akesana)
Hi Polina,
I did not get you completely could you please elaborate a bit?
posipova
20-Turquoise
(To:akesana)
If you look at the Google Maps widget configuration (the part in the screenshot above), there are differnent tooltip locations you may assign. For example, if you have a google location picker widget, you may bind it to one of the Tooltip Locations, and then assign a tooltip mashup.
This would not fit your described use case, but there is no way to assign individual double clicked events on different locations.
