How to Set the Property Value of an Implemented Thing?
lorenmc
I would like to change the value of a property of an implemented Thing from a Mashup.  I cannot find a service that will allow me to do that.  I can find the service at the Thing level but not at the template level.  I have a list of implemented things and I want to change the value of the property for the Thing that is selected in the list.  Can this be done?
Loren
1 REPLY 1
when you add the entity in the mashup, you need to check the "dynamic" box when you select the template.  Then you will see the setproperties service
