The message you are trying to access is permanently deleted.
Hi ,
I am showing some dynamic data in a grid and i want to add two columns having a image and a button and button should be bonded with some customized events and action.
Is this is possible or any widget is already present ?
Thanks in Advance
This is something you can accomplish using the Repeater widget.
How did you solve this problem? Which objects did you use?
Claudio
