I'm using logout button widget for this I select confirmation Required when I click on yes confirmation, it show me login information popup. I want to show when I click on logout button then it will redirect on login page Please refer below attachment and suggest How do I redirect to login page after click on logout button ??
Thanks in advance
As the Logout button recieves mashup directly now,it cannot redirect to FormLogin page.
How about a link widget with "replace" or "this page" option, and direct to FormLogin URL. Bad part is that it does not terminiate the session.
The logout button widget has a redirectMashup field to configure
Thanks for your reply ,By using organization I create login page for this can you please suggest How do I redirect to login page with (Organization link )??
