While adding a http thing property in another thing,
in the binding the http thing is not visible,
soo, how can i use that property here;
Please help me out.
Thank you.
I have tried to reproduce a similar scenario.
I have a thing with HTTPConnector as Base Thing Template.
After creating a property I wanted to bind it with another property from a different thing.
I have used Manage Bindings. The property can be binded with other properties from different Things.
Is this what are you trying to achieve ?
Ciprian
Yeah the situation is similiar,
but i've not created the thing template,
instead i've cretaed both as things only
Yeah the situation is exact similiar,
but instead of http thing as base template,
i've used odata connector,
Please help out.
I have used Base Thing Template as ODataConnector in the Thing.
I can use Manage Bindings to bind properties from a different Thing (local) to the properties in my current Thing.
I can see the bindings in the Source section of Properties.
