How to add default suffix to entity name?
SaiSameera
I want to give entity name as TreeThing_abc where _abc is the suffix. Whenever I want to give the name for any entity, _abc should come by default and then I'll add the prefix name based on the entity that I create. Is there any possibility to get default name for entity name.
thanks
sameera
You just need to use CreateThing snipped and add the desired sufix:
var sufix = "_mySufix";
Resources["EntityServices"].CreateThing({
 description: "",
  thingTemplateName: "GenericThing",
  tags: undefined
6 REPLIES 6
Not with the Composer, but you can create a custom service in order to create entities and in this service add the suffix by the rules you desire, it's how we do it.
SaiSameera
(To:CarlesColl)
Thanks CarlesColl
Is there any snippet to add suffix for entity name.
sameera
 description: "",
  tags: undefined
SaiSameera
(To:CarlesColl)
Hi CarlesColl,
I'm able to create a thing with the suffix. But I want to get the suffix whenever I click on the name to create a thing or ThingTemplate or any entity.
That's what I said on my first answer that can't be done through the Composer.
tcoufal
(To:SaiSameera)
You can create a Mashup utilizing your custom services. Then you can assign this mashup as your home mashup in your HelperThing. And access it simply by clicking on HomeMashup in EntityInformation section.
