How to add filter in time series chart based on time stamp?
bgupta-2
Dear Team,
Currently showing my time series chart
But I need to show filter based on date time stamp.
posipova
20-Turquoise
(To:bgupta-2)
You can use either time selector widget and bind StartDate and EndDate or try the data filter widget if you are using a Query service to populate your time series chart. Then you would need to bind your data filter widget to the query parameter and load the results into the time series chart.
3 REPLIES 3
posipova
20-Turquoise
(To:bgupta-2)
Thanks.
Same thing has done. I need time interval 1 hr. For this I have selected interval type hour and interval value is 1. But still getting interval only 5 min.
Property
Thanks.
Property
