How to add grid inside gird column or any other widget in grid column
RN_8282441
7-Bedrock
supandey
(To:RN_8282441)
Hi Raj, what exactly is your use case? If it could be done with an Image you can pass that to the Grid, e.g. create either a property with Image as datatype or create or create an Infotable with Image as field that can then be bound to the Grid.
If you are looking to show tree type hierarchy then may be it better to use the Tree widget that's capable of showing nested Infotables.
