How to delete a token from the localization table
  • January 12, 2016
  • 2 replies
  • 7238 views
I have a localization table I use and by mistake I added few tokens, I want to delete them, they are on the default table.
I cannot find where I can do it.
TW version I use:  6.0.2-b456
Thanks.
22-Sapphire I
January 13, 2016
A bit of a challenge, but there is a DeleteToken service that you can invoke using the REST API or in a mashup.
aelgov1-VisitorAuthor
Thanks Pai Chung,
I'm not sure I fully understand how to do it, but I just want to say I meant how to do it in the composer, I dont want to do it from the code.
22-Sapphire I
January 13, 2016
Unfortunately at this time there isn't a way to directly do it within composer, so you will have to do it by either building a mashup and using the DeleteToken service, or invoking it through the REST API.
sorry for english, i'm using Google Translate (Czech to English)..
Just delete text of token in Default localization table and save it. The token is removed. Functional in version 7.1.0.
