How to add iframe from an external report into Thingworx mashup
raghunayak
6-Contributor
Hello Guys,
I am trying to add a iframe of a report from an external system into Thingworx mashup. So far only Webframe widget can do it but it comes with a top menu that I want to avoid ? Is there a way to do it within mashups so that I can shows report from a different system along side Thingworx data in a mashup ? Thanks
PaiChung
22-Sapphire I
(To:raghunayak)
the webframe is the way to go that is basically an iframe
you can have that webframe take up a smaller amount of space so you can add Thingworx information around it.
Not sure what you mean by 'menu' that you want to avoid, if that is from the other site you are showing, then you'll have to see if there is a link or switch to the information that will not display that menu.
