How to add new element when click button
vxba
I have a popup with some controls as attached
How can I add new element when click the Add button or remove when click Delete button
for example: when I click Add button new element will be added as Field2 + textbox
vxba
(To:raluca_edu)
It can workaround by creating a DataTable and use Repeater to load items
2 REPLIES 2
raluca_edu
(To:vxba)
I don't know if you found a solution to this, but from my perspective it is not possible to add dynamically elements into mashup.
The only method I have seen until now is to create widgets and make them visible when necessary.
Best regards,
Raluca Edu
vxba
(To:raluca_edu)
