I want to add property values of a thing to an infotable/datatable thing in ThingWorx,
For Eg: I have a datatable with a datashape having three columns(column 1, column 2, column 3)
also, I have 3 properties (column1Prop, column2Prop, column3Prop)
I want to add these properties as a Row to the datatable.
Can anyone help me please.
Thanks in advance.
Aditya Gupta
Hi Aditya,
you would create a subscription to a DataChangeEvent that fires whenever one of those properties was changed.
in that subscription you would add a row to the dataTable. Roughly like this:
let v=DataShapes["TheDataShapeOfYourDataTable"].CreateValues();
v.AddRow({prop1:eventData.newValue.prop1, prop2:eventData.newValue.prop2, prop3:eventData.newValue.prop3);
me.AddDataTableEntry({values: v});
The question is though why you would not use Value Streams instead which are explicitly made for that use case. Just assign a value stream to the thing and set the three properties to "logged".
Hi @Surya_Tiwari ,
I am not able to understand this, I will just brief you once again what I want to achieve:
I have few properties which are changing, so everytime the value changes I want to add those property values into a datatable.
eg. I have property1, property2 & property3 so evertyime the value of these properties changes I want to record them into a datatable.
Do you have any solution for this?.
Thank You.
Aditya Gupta
Hi Aditya,
Hello @Rocko ,
Thanks for your reply.
I am new to thingworx so, can you please provide me a step by step solution?
Sounds good. Please do not forget to plan purging the value stream regularly to not overfill your database. You can read about it in the help and here: https://www.ptc.com/en/support/article/CS271772
I also recommend the ThingWorx Learning Paths to get started with ThingWorx: https://community.ptc.com/t5/IoT-Tips/ThingWorx-Learning-Paths/ta-p/841623
Hi @Rocko ,
Good Morning,
What if I want to move this stored data to some other database or any storage for my future reference
then how do I go about it?
Thanks in Advance.
One way of doing it is to create a JDBC connection to the other database. Then with a scheduler, query the data you want to move out, iterate over the returned infotable and insert the rows into the other database.
For reference:
https://community.ptc.com/t5/IoT-Tips/Working-with-External-Databases-Part-1/ta-p/833992
Okay.
I will surely try & let you know if any issues.
Thank You.
Aditya Gupta
Hi @Rocko ,
Good Morning,
Value Stream did worked for me.
I set the properties to be logged & then executed QueryPropertyHistory Service.
Hope this is the right way.
Thanks & Regards,
Aditya Gupta
