Is it possible and how to allow the user to mark a check box named , for exmaple, "remember me" in the login form, so that the user don't need to input the user/password everytime ?
Sean
That's not an OOTB function, you may need to add this function to the FormLogin.jsp file on your own if required.
The file is under Tomcat/ webapps/ Thingworx/ Login
Note that if you upgrade the TWX server, the new ThingWorx folder will not contain your edited jsp file, so keep a copy for your solution
