Hi ,
I am using the Event router widget. The output of Event router is bind to value display widget.
The output result is string. I want to display the text in red color. I have given style definitions to Value display widget. After binding the event router , its overriding my style definitions. I could not see the text in red color.
Could you please suggest how to apply the style definition to event router output text.
Thank you.
You have to set the ValueDisplayValue with a red style definition.
The red style you defined is for the text when there is no value.
Thank you for the solution.
