Dears,
I have a service that needs to be executed after Thingworx is started or restarted, is there a way to automatically execute it after startup, thanks!
BR,
Chason
Hi @CZ_9645217
You can use ThingStart event in the subscription to execute the service.
Note: ThingStart event will be triggered when you save changes. Consider this point while building your logic
/VR
Hi @CZ_9645217
/VR
