How to center align the tabset
PG_10250187
11-Garnet
I would like to center align the tabset. I have also attached the image for reference.
Note: I inspected and added the below CSS it worked. But if I try writing in custom CSS then it didn't work. So I need the CSS to be added.
justify-content: center;
7 REPLIES 7
Not sure about CSS.
But we approached this use case with "Button Bar" and "Expression". And, its working fine.
I need that tab to be in the middle
try below code.. its working for me..
.widget-ptcstabset::part(tabs-header)::part(tabs) {
I tried it didn't work for me.
Try to import the attached mashup and check.
If not working, please share
  • Thingworx version
  • Tab widget name (Tabs -> Standard, Tabs -> Legacy, Tabs - Responsive -> Legacy)
  • Your mashup if possible
Thank you for the reply.
ThingWorx Version - 9.3.0
Tab widget name - Tabs -> Standard
Also attached mashup for reference.
Mine... ThingWorx 9.1.11-b1017
Your mashup is working fine here. Might be an issue with 9.3
