We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
I don't want to reinstall analytics server again. is there any service that could do that .
If you are referring to the name of the AnalyticsServer thing created, this can be changed in <ThignWorxAnalyticsServer>/config/analytics-server.properties.
You will need to restart ThingWorx Analytics Server after this change.
New things with the new name will get automatically created.
You can then delete the old things if they have not been used anywhere.
Kind regards
Christophe
Kind regards
Christophe
Thank you bro
If the above answer solve your issue, it would be good if you can mark it as correct.
That will help other to find the answer quicker in the future.
Thank you
Kind regards
Christophe
Done bro
