How to change session timeout setting just for a single user?
njain-31
6-Contributor
I followed below steps:
Subsystems -> UserManagementSubsystem -> Configuration, there is a setting called 'Idle Session Timeout'. The default value is 30 minutes. Set it to desired time > Restart Tomcat .
but this change the session timeout for all the users, I am only looking to change it for a single user.
You can have a custom user property setting with the timeout and another property with last operation (that you will need to update each time the user interacts with the server), and a timer that every minute (for instance) checks for logged in users (GetActiveUsers), and for those which are logged check the timeout setting and execute TerminateUserSessions accordingly.
slangley
(To:njain-31)
Hi @njain-31.
There currently is no mechanism for setting the session timeout for selected users.  It's a global setting.
--Sharon
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
njain-31
6-Contributor
(To:slangley)
Can you assist me with possible ways to keep User logged in session alive for log time.
Will external application like auto click on web page can work?
