How to close the mashup on button click
madnan
1-Newbie
How to close the mashup on button click?
please hep with the solution.. thanks in advance
4 REPLIES 4
nkhose
1-Newbie
(To:madnan)
Hi
Can you be more specific are you trying to close the mashup tab or trying to close a Pop-up open from
parent mashup  , in later case the mashup itself has closeifpopup event
madnan
1-Newbie
(To:nkhose)
Thank you for your reply, how to do if i have to close the mashup tab on button click?
Add an expression widget, and set it on Expression=close();
Then you just need to trigger that expression widget whenever you want to close the browser window.
Thank you so much. It worked
