Nov 18, 2016 1:25 PM UTC
How to close the mashup on button click
How to close the mashup on button click?
please hep with the solution.. thanks in advance
Nov 18, 2016 2:41 PM UTC
Hi
Can you be more specific are you trying to close the mashup tab or trying to close a Pop-up open from
parent mashup  , in later case the mashup itself has closeifpopup event
madnan1-VisitorAuthor
Nov 24, 2016 1:17 PM UTC
Thank you for your reply, how to do if i have to close the mashup tab on button click?
Nov 24, 2016 1:47 PM UTC
Add an expression widget, and set it on Expression=close();
Then you just need to trigger that expression widget whenever you want to close the browser window.
Nov 25, 2016 9:36 AM UTC
Thank you so much. It worked
