How to compare two infotable fields
Velkumar
Hello all,
Can anyone tell me, how to compare two infotable fields are same ?
VR
Ok, then you need to recover Infotable definition fields, to do that you can use the following code:
 var fields ;//
    if ((infotable.dataShape==null)||(infotable.dataShape==undefined)) {
        fields = infotable.ToJSON().dataShape.fieldDefinitions;
    } else {
        fields = infotable.dataShape.fields;
Than you do for both infotables, and check if they have the same fields.
4 REPLIES 4
What does you mean with two infotable fields? All the rows for the same field name or what?
Velkumar
(To:CarlesColl)
Hello @CarlesColl,
I want to compare whether both Infotable have same field's. We are not comparing rows.
VR
 var fields ;//
    } else {
slangley
23-Emerald II
(To:CarlesColl)
Hi @Velkumar.
If the response provided by @CarlesColl answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
