How to configure Google account in Flow?
Janakiraman-P
Am trying to use Send an Email connector on Flow, Unable to add new account in Authorize Gmail showing no results found instead of Add New.
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:oparfon)
Hi @Janakiraman-P and @oparfon.
Please check this article for guidance.
Regards.
--Sharon
5 REPLIES 5
Follow this help center instructions to configure Connector OAuth settings. Once done you will have the option available.
Janakiraman-P
(To:rjanardan)
Hi @rjanardan ,
Am done with the configuration till deployment. Now I could able to see the option, thanks.
But still am not able to configure it on Flow, the following error coming while giving permissions.
Is this error because of my Network?
Janakiraman P
oparfon
(To:Janakiraman-P)
 I have the same issues with the activation of Google account for FLOW.
Did you figure out how it works?  Should I have a GSuite Account to be able to activate APIs?
Best Regards
slangley
23-Emerald II
(To:oparfon)
Regards.
--Sharon
Hi @Janakiraman-P.
If one of the previous posts helped to solve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
