Hi, I want to populate two bom structures (current version and other some version) in a single tree advanced grid widget with the option of expanding nodes in both the columns. If I am expanding one column bom structure the other column bom structure should also expand. How is it possible?
Have you enabled ExpandLoadedRows?
Could you please attach a screenshot of what you want to achieve?
Thank you,
Raluca Edu
Hi @majorkumar3.
Have you found a solution to your question? If so, please feel free to post it here and mark it as the Accepted Solution for the benefit of others with the same question. If you are still searching for a solution, please provide the additional information requested by Raluca.
Regards.
--Sharon
