I have a config.json (it works fine) like
"certificates": {
"validate": true,
"allow_self_signed": false,
"cert_chain": [
"/path2cert/entrust_l1k.pem",
"/path2cert/entrust_g2.pem"
How could i write it in programming? Because ServerCertFileInfo property only allow me to specify one cert file
var client = new ConnectedThingClient(new ClientConfigurator
AllowSelfSignedCertificates = false,
DisableCertValidation = false,
ServerCertFileInfo = new CertFileInfo { CertType = 0 /* TLS */, FilePath = @"/path2cert/entrust_g2.pem" },
Any help would be greatly appreciated
Hung Tran
Some helpful articles:
From "Help Center" - ".NET SDK: ClientConfigurator Class": http://support.ptc.com/help/edge_sdk_dotnet/r5.8.0/en/index.html#page/dotnet_sdk/c_dotnet_sdk_refere...
Discussion earlier - "Client certificate authentication in Java": https://community.ptc.com/t5/ThingWorx-Developers/Client-certificate-authentication-in-Java/td-p/528...
Thanks for your quick reply, however you misread my question, the Thingworx server is configured properly, it's already been working with config.json + wsems / localems. I just don't know how to setup cert chain for the ClientConfigurator object.
Hung Tran
Hello @htran-21 ,
pls check the following article to set up cert for CCO.
https://www.ptc.com/en/support/article/cs272670
Let me know if that helps.
Regards
Bhawna
Hi Bhawna,
I visited the link but that does not provide any details.
Hung Tran
You can find a detailed solution in the attached PDF file.
