How to configure widget?
Hello friends, I'm a beginner on the platform, and I use the free version momentarily, through research I found a dashboard that I really liked.
would like your help to know if with the tools of version 8.5. Can I configure a layout this way, or, just creating it?
I thank you for your availability.
Look at the attached Mashup CMOTrendMashup.
If you change the value of property trend in CMOTrendThing from up to down to equal, the icon display will change.
You can then configure with desired icon in the Style definition and configure text and background colour in the properties of the labels.
Hope this helps.
Christophe
Hope this helps.
Christophe
