How to convert infotable to integer?
YD_9850038
Hello Experts,
I have some sql queries that retrieve data from DB and by default it accepts as base type of the output only an infotable, i would like to convert the output to integer!!
Youss
PaiChung
22-Sapphire I
(To:YD_9850038)
First make sure you assign an appropriate datashape or know the columns of your query output (looks like you are getting one column: 'idusuario')
So in your wrapper service, you'll have to do something like:
try {
var SqlQueryResult = me.queryUserByIdCard({
idTarjeta: idTarjeta /* INTEGER */
//At this point SqlQueryResult is still an integer
//Now generate your Integer result
var result = SqlQueryResult.idusuario;
//Make sure your output type of this wrapper service is set to Number or Integer
Hope that helps
3 REPLIES 3
PaiChung
22-Sapphire I
(To:YD_9850038)
Wrap the SQL service with a JS service that invokes the SQL services and  takes the returned infotable, extracts the value and returns it as an integer.
I have this service that execute the query:
try {
var queryUser = "SELECT idusuario FROM usuario where idtarjeta="+idTarjeta;
logger.debug("DatabaseController.JavaScriptQuery_TablaUsuario(): Query - " + queryUser);
var result = me.RunDatabaseQuery({query:queryUser});
} catch(error) {
logger.error("DatabaseController.JavaScriptQuery_PersonsTable(): Error - " + error.message);
It returns an infotable as output!
I have another service where i am trying to do something like:
try {
} catch(error) {
So i assign the output of queryUserByIdCard to SqlQueryResult  but i still is an infotable, i dont see how i can do, do you have an idea?.
Yous
PaiChung
22-Sapphire I
(To:YD_9850038)
try {
Hope that helps
