How to convert static widget in responsive?
einsfele
Hi all,
I am working with widget static called Progressive Gauge.
But this widget is not responsive, therefore it does not resize on the screen.
My question is: Can I convert the static widget (Progressive Gauge) in a responsive widget?
Tks,
Leonardo
Sugumar_5656
(To:einsfele)
Hi @einsfele ,
Use the attached progress gauge widget. which is completely responsive one.
You can change any static widget to a responsive widget. for that, you need to change its code at the extension level.
Regards
Sugumar R
Sugumar_5656
(To:einsfele)
Hi @einsfele ,
Regards
Sugumar R
einsfele
(To:Sugumar_5656)
Thank you @Sugumar_5656
It helped me a lot
Leonardo
